       << Click to display table of contents >> TRVAudioViewer.ReceiverSource, GUIDFrom |
ReceiverSource is an audio source to visualize audio data received from the network, for example, by TRVCamReceiver component.
property ReceiverSource: TCustomRVReceiver;
property GUIDFrom: TRVMAnsiString;
If you assign value to ReceiverSource, AudioSource is reset to nil.
If GUIDFrom is empty, this component shows sound activity from all senders.
You can specify GUID of specific sender to indicate only sound received from this sender.
See also:
Default value
GUIDFrom: '' (empty string)
