       << Click to display table of contents >> GetListOfAvailableSampleFormats Procedure |
Fills AList with audio sample formats acceptable for the Codec.
Unit [VCL and LCL] MRVFFMpegLists;
Unit [FMX] fmxMRVFFMpegLists;
procedure GetListOfAvailableSampleFormats(Codec: TRVAudioCodec; AList : TStrings);
This function works only if FFmpeg is available. Otherwise, it simply clears AList.
Each added item has a text describing the sample format, and an object equal to the corresponding sample format (a TRVSampleFormat value type-casted to TObject).
Internally, this function uses GetSampleFormatName to assign text to items.
