<< Click to display table of contents >> GetListOfAvailableFFmpegFileFormats Procedure |
Fills AList with video file formats available for encoding.
Unit [VCL and LCL] MRVFFMpegLists;
Unit [FMX] fmxMRVFFMpegLists;
procedure GetListOfAvailableFFmpegFileFormats(AList : TStrings);
This function works only if FFmpeg is available. Otherwise, it simply clears AList.
The function checks availability of encoders of the following file formats:
•MP4
•AVI
•MPEG
•3GP
•ASF (if MRVCODEC_MSMPEG4v3 is $defined)
•FLV
•MKV
•MOV
•RM
•MJPEG
Available formats are added to AList.
After calling this function, you can use AList to choose a file extension for OutputFileName property of TRVCamRecorder component.
