Example 2: playing a camera video (no wait mode)
This example shows how to play a video from an IP camera in a "no wait" mode: operations are performed in background threads, without waiting. When an operation is finished, an event is called. This is a recommended mode, you can provide a visual feedback while waiting, and the user can interrupt a long operation.
Example
1. Place RVCamera1:TRVCamera and RVCamView1:TRVCamView on the form. Assign RVCamView1.VideoSource = RVCamera1.
2. If you need a separate component for controlling the camera movement, place RVCamControl1: TRVCamControl on the form. Assign RVCamera1.CameraControl = RVCamControl1.
3. Assign RVCamera1's properties: the camera address and the user name and password. For example:
•CameraHost = 'novatron.dyndns.tv',
•CameraPort = 8888
•UserName= 'demo15'
•UserPassword = 'demo15'
•DeviceType = rvdtIPCamera
4. Assign RVCamera.CommandMode = rvsmNoWait.
5. Add in TForm1.FormCreate:
RVCamera1.SearchCamera;
6. Create the event handler for RVCamera1.OnSearchComplete event:
procedure Form1.RVCamera1SearchComplete(Sender: TObject;
  Status: Integer);
  if Status = 0 then
    RVCamera1.PlayVideoStream;
Note: This example uses a camera search. If the camera is of a type specifically supported by the component, it will be controllable. In the simplest case, displaying a video is as simple as assigning the URL property and calling the PlayVideoStream method.
