       << Click to display table of contents >> TRVStyleTemplateCombo/ListBox.ShowAllStyles |
Specifies whether the component displays all available style templates.
property ShowAllStyles: Boolean;
If True, the component displays all style templates from Editor.Style.StyleTemplates.
If False, the component displays:
•style templates in use (i.e. style templates referred by Editor.Style.TextStyles and ParaStyles);
•style templates having QuickAccess=True
•"All styles" item (if not all style templates are displayed)
If SmartHeadings=True, the component uses a special procedure to calculate a visibility of "heading 1".."heading 9" style templates.
When "All Styles" item is clicked:
•if OnClickAllStyles is assigned, it is called
•otherwise, the combo-/list-box temporarily displays all style templates.
Default value:
False
See also:
