       << Click to display table of contents >> TRVStyleTemplateCombo/ListBox.ControlPanel |
Links this component with a control panel.
property ControlPanel: TComponent;
You can assign a TRVAControlPanel component to this property. If this property is not assigned (nil), the component uses MainRVAControlPanel.
ControlPanel is used to display localized captions according to its Language.
