       << Click to display table of contents >> TRVFontComboBox.DropDownWidth |
Gets or sets the width of the of the drop-down portion of a combo box.
property DropDownWidth: TRVPixel96Length;
This property is used if Preview = True.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value:
300
