TrvActionRemoveHyperlinks is the action for "Remove Hyperlinks" command.
Unit RichViewActions;
Syntax
TrvActionRemoveHyperlinks = class(TrvAction)
Description
This action converts all hyperlinks in the selected fragment to a plain text. This action does the same work as TrvActionInsertHyperlink, if the user entered an empty link target.
This action is a wrapper for TrvActionInsertHyperlink action referenced in ActionInsertHyperlink property.
