       << Click to display table of contents >> TrvActionParaList.IndentStep |
Defines the step for increasing LeftIndent and MarkerIndent of list levels.
property IndentStep: TRVStyleLength;
This value is measured in GetControlPanel.UnitsProgram.
This property is used to adjust indents in the predefined set of lists (indents are adjusted when this action is executed for the first time).
Default value:
24
This default value assumes that this property is measured in pixels. For twips, this value may be too small.
See also:
