       << Click to display table of contents >> TrvActionOpen.Filter |
Defines a set of file formats appearing in the file opening dialog.
property Filter: TrvFileOpenFilterSet;
If ffiCustom is included, formats listed in the CustomFilter property are used.
Name and extension of RichView Format (RVF) may be customized, see GetControlPanel.RVFFilter.
Default value:
all formats
