       << Click to display table of contents >> TrvActionInsertTable.VOutermostRule |
Allows showing vertical lines between the left and the right table borders and cells.
property VOutermostRule: Boolean;
This property is assigned to the table property of the same name.
Vertical rules are drawn only if VRuleWidth>0.
Default value:
False
