       << Click to display table of contents >> TrvActionInsertTable.OnInserting |
Occurs before table is inserted.
type
TRVAInsertTableEvent = procedure (Sender: TrvActionInsertTable;
table: TRVTableItemInfo) of object;
property OnInserting: TRVAInsertTableEvent;
This event occurs after all the action's properties are applied to table. You can make additional changes in this event.
