       << Click to display table of contents >> TrvActionInsertTable.ColCount |
Defines the count of table columns.
property ColCount: Integer;
This property is used as an initial value for initializing a table dialog. If the user chose to remember dimensions for new tables, value from the dialog is assigned to this property.
This property is ignored in ShowTableSizeDialog method.
Default value:
2
