       << Click to display table of contents >> TrvActionInsertPicture.DefaultExt |
Specifies the default file extension.
property DefaultExt: TRVALocString;
DefaultExt specifies a file extension that is appended automatically to the selected file name, unless the selected file name already includes a registered extension. If the user selects a file name with an extension that is unregistered, DefaultExt is appended to the unregistered extension.
This property is assigned to DefaultExt property of the file opening dialog (TOpenPictureDialog).
Default value:
'bmp'
