       << Click to display table of contents >> TrvActionInsertHyperlink.UnderlineColor |
Defines the underline color for hyperlinks.
property UnderlineColor: TColor;
This property is used only if style templates are not used (i.e. the target editor's UseStyleTemplates=False). If style templates are used, the action applies StyleTemplateName instead.
This property is used when converting text to hypertext, if rvhlHoverUnderlineColor is included in ValidProperties.
A value of this property can be changed by the user in the hyperlink properties dialog.
Default value:
clNone (instructs using Color)
