       << Click to display table of contents >> TrvActionInsertHyperlink.TerminateHyperlink |
Helps to terminate hyperlinks when typing in rve.
procedure TerminateHyperlink(rve: TCustomRichViewEdit);
If the selection is empty, the current text item is a hyperlink, and the caret is at the end of this item, this function assigns the index non-hypertext style to the current text style (rve.CurTextStyleNo). GetNormalStyleNo is used.
Example [VCL]:
procedure TForm1.RichViewEdit1KeyPress(Sender: TObject; var Key: Char);
if Key in [#9, ' ', ',', ';'] then begin
rvActionInsertHyperlink1.DetectURL(RichViewEdit1);
rvActionInsertHyperlink1.TerminateHyperlink(RichViewEdit1);
When the user types something at the end of a hyperlink, new characters are added to the hyperlink's text. But when he/she types a space character (or tab, or comma, or Enter, or semicolon), the current text style becomes a non-hypertext, so this and subsequent characters will not be added to the hyperlink's text.
You should call this method:
•in OnKeyPress event (in OnUTF8KeyPress for Lazarus) when the user types tab, space, comma or semicolon characters
•in OnKeyDown event when the user pressed ENTER.
