       << Click to display table of contents >> TrvActionIndentInc.IndentMax |
Defines the maximal possible value for the indent.
property IndentMax: TRVStyleLength;
The action does not increase the paragraph's indent above this value.
This value is measured in GetControlPanel.UnitsProgram.
Default value:
200
This default value assumes that this property is measured in pixels. For twips, this value may be too small.
