       << Click to display table of contents >> TrvActionCustomColor.CallerControl |
Specifies the control (for example a toolbar button) which executed this action.
property CallerControl: TControl;
Assign this property if you use Delphi 5. For the newer versions of Delphi, the caller control is determined automatically (using ActionComponent property).
A color-picker window is positioned relative to this control. If this control is undefined, a color-picker window is displayed at the mouse pointer position.
