       << Click to display table of contents >> TrvActionAlignCustomJustify |
TrvActionAlignCustomJustify is a base class for the actions changing alignment of selected paragraphs to the both left and right sides.
Unit RichViewActions;
Syntax
TrvActionAlignCustomJustify = class(TrvActionAlignment)
Description
Properties:
LastLineAlignment is applied to the selected paragraphs, if UseLastLineAlignment=True.
This action is not used directly. The following actions are inherited from it:
