       << Click to display table of contents >> TRVAControlPanel.OnMarginsChanged |
Occurs after some action changes TCustomRichViewEdit control's margins (LeftMargin, TopMargin, RightMargin, and BottomMargin properties).
property OnMarginsChanged: TRVAEditEvent;
Margins can be changed by TrvActionOpen and TrvActionBackground actions.
If you use TRVRuler, you must update it in this event:
procedure TForm1.RVAControlPanel1MarginsChanged(Sender: TrvAction;
Edit: TCustomRichViewEdit);
RVRuler1.UpdateRulerMargins;
