       << Click to display table of contents >> TRVAControlPanel.DownloadInterface |
Allows using a third-party components to download images and external files (such as CSS files) from HTTP and HTTPS links.
property DownloadInterface: TRVACustomDownloadInterface;
The actions may need to download images when loading/inserting RTF, DocX or HTML files, if these files contain external images or CSS files.
You can assign one of the following components to this property:
•TRVAIndyDownloadInterface (to use Indy)
•TRVAClDownloadInterface (to use CleverComponents)
See also
•OnDownload event
•InitImportPicturesAndFiles, DoneImportPicturesAndFiles methods
