       << Click to display table of contents >> Third-Party Tools |
The following additional components can be optionally used in RichViewActions.
Spell checkers:
•Polar Spell Checker ActiveX
Downloaders:
•Indy
File readers and writers:
•RichViewXML for opening and saving documents in XML format (freeware)
User interface:
•Toolbar 2000 (free for non-commercial use), TBX, SpTBXLib for providing alternative versions of TRVAPopupMenu
•TNT Controls for Unicode support in Delphi 5-2007.
By default, RichViewActions use simple 16-color 16x16 images.
In Delphi 2009+ (or if you use a thirdparty image list component supporting semitransparent images), you can use TRichView icons, or the following alternative toolbar images:
