       << Click to display table of contents >> RVA_TranslateUnits procedure |
Translates units of measurement to the current language.
procedure RVA_TranslateUnits(SL: TStrings; ControlPanel: TComponent=nil);
If ControlPanel is a TRVAControlPanel component, the function uses it. Otherwise, it uses MainRVAControlPanel.
SL must have 6 items corresponding to the following units, in the specified order:
•Inches,
•Centimeters,
•Millimeters,
•Picas,
•Pixels,
•Points.
The name of the current language is returned as ControlPanel.Language, or by RVA_GetLanguageName function.
The current language can be changed by assigning a new value to ControlPanel.Language, or by calling RVA_SwitchLanguage procedure.
