TRichView 18.4 - RAD Studio 10.4 Sydney
TRichView 18.4, ScaleRichView 9.2, Report Workshop 2.2
A trial version is available: https://www.trichview.com/download
A full version can be found in the protected section of this forum (or old setups can check for updates and download new versions).
The new version of our components supports Delphi and C++Builder 10.4 Sydney
https://www.trichview.com/forums/viewto ... f=6&t=9967
TRichView 18.4: Per-Control VCL styling
Per-Control VCL Styling
Our controls support VCL themes (introduced in RAD Studio XE2).
In editors, they are activated if you assign UseVCLThemes property = True.
Delphi 10.4 allows to set different styles per control. Our components support this feature: you can use StyleName properties of TRichViewEdit, TSRichViewEdit and other visual controls.
RichViewActions (commands and dialogs to build text processor UI) support this feature as well: previews in dialogs use a style of the target editor:
In the example above, the application uses "Tablet Light" theme, while the editor uses "Glow" theme.
TRichView 18.4: other features
Other changes
HTML Export
We improved HTML export (both a simplified HTML and an HTML+CSS versions).
One of the most noticeable tweaks: better HTML code indenting, so it's simpler to read it.
VirtualTree Support
Since this update, our Setup supports the TurboPack's version of Virtual TreeView too (it can be installed from GitHub or using GetIt package manager).
The setup checks which version is installed, and adjusts TRichView+VirtualTree packages accordingly.
TRichView mailing list
I just sent emails announcing this update to all TRichView customers who ordered in 2011 and later.
If you did not receive my email, this mean:
- your email server rejected my email, or
- you unsubscribed from my list, or
- you did not subscribe (using the link that I sent together with the registration key), or
- you did not agree to receive my email when I sent notification about GDPR.
If you did not receive my email, but want to receive announcements (not often, up to 3 emails in a year), please contact me, I'll send you information how to subscribe to my mailing list or how to change email address in the subscription.
