Best way to handle using TRichView
jgkoehn
Post by jgkoehn »
Greetings Forum,
We have a question in regards to the best way to create something in TRichView.
The text would look like this
Ἐν | ἀρχῇ | ἦν | ὁ λόγος, καὶ ὁ λόγος ἦν πρὸς τὸν θεόν, καὶ θεὸς ἦν ὁ λόγος.
Ιn | beginning | was | the Word, and the Word was with - God, and God was the Word.
Prep | Noun | Verb | Article Noun Conj Art Noun ...
A table would probably be ideal. However, a table does not wrap at then end of the line. So does one do mini tables for each word set?
Can tables be side by side in TRichView.
Thoughts?
Re: Best way to handle using TRichView
Sorry, I do not understand how it should look like, can you attach a picture?
jgkoehn
Post by jgkoehn »
A couple examples
Sorry, it is not possible currently in TRichView. Tables cannot wrap, and tables cannot be placed side by side (it is planned in future updates, but I cannot tell when it will be implemented).
Well, there is a solution: each block can be a separate editor, inserted in the main editor. But this solution is suitable only for relatively small documents. Here is an example how to create documents containing nested editors so that it can be stored in RVF: https://www.trichview.com/forums/viewto ... f=3&t=2199
jgkoehn
Post by jgkoehn »
I have tried this but it slows things down about 11 seconds to render the data. What work around could I do to make Tables side by side? Is it complex?
Unfortunately, tables cannot be placed side by side. Planned for future versions.
