RVMedia - Video Chat Encryption
Hello there,
I am a university student and our school gave homework for students for the end of the year assignment.
I am trying to complete my homework using the trial version of your product.
My homework is an encrypted video chat application.
Similar to the following topic:
trichview. com /forums/viewtopic.php?f=17&t=7827
I was able to encrypt the sound, messages sent.
The point I get stuck is the encryption of the video call.
Which event should I use for this?
Even if there is no event for this, it is enough to have a trigger that I will see the stream format before the file goes.
I would be very happy if you help,
Best regards.
Best regards.
Re: RVMedia - Video Chat Encryption
Sorry, TRVCamSender/Receiver do not have events where you can encrypt/decrypt video. I'll check if I can add them, later in this week.
Thank you. Where can I follow the updates?
Check the "Announcements" forum https://www.trichview.com/forums/viewforum.php?f=6
Thanks, I'm waiting excitedly.
Well, in my working version, I added OnEncodeVideo event to TRVCamSender, and OnDecodeVideo event to TRVCamReceiver.
They can be used to encrypt/decrypt video frames.
However, this change is not large enough to upload a new version. Are you a registered RVMedia user? If yes, I can send changed files to you directly.
Unfortunately, no.
As a student, I was developing it with trial version since it exceeded my budget.
My teachers said it was okay for me to use a trial version.
What can I do for it?
The only thing I can think of is to create a student package that proves to be a student.I can do that.
Would it be a problem for you to create a package that does not exceed my budget?
If it creates; I will wait if the new version will not be too late.
My deadline for handing in my homework: June 8.
I want to deliver it before, but I can wait for you.
Hi Sergey
Is it possible to have the modified code for the encrypted chat video
I'm a registered user.
Many Thanks
Alfred
Many Thanks
Alfred
The events are included in RVMedia v7.4
