Need to remove Focus rectangle
I Need to remove the focus rectangle, the pdf documentation refers to the property ShowFocusRect, but when I try to reference it a compilation error comes up.
Re: Need to remove Focus rectangle
You are right, we removed ShowFocusRect but forgot to update the help file.
Simply assign clNone to FocusLineColor (TAlphaColorRec.Null instead of clNone for FMX)
Thank I will try it.
