I handled subdocuments with the following procedure ,sRveExport is a TSRichviewEdit, it worked perfect until today. Exception message is : list index out of bounds(-1),exception only occured on the header file's loading when "loadRVF",the footer file's loading is right,what I missed?
procedure TfrmQuestionExport.HandleSubDocuments;
c: TColor;
sRveExport.PageProperty.TitlePage := True;
sRveExport.PageProperty.HeaderVisible := True;
sRveExport.PageProperty.FooterVisible := True;
c := clWhite;
if FileExists(myPath + HeaderFN0) then
sRveExport.SubDocuments.Items[srvhftFirstPageHeader]
.LoadRVF(myPath + HeaderFN0, c, nil, nil);
if FileExists(myPath + HeaderFN) then
sRveExport.SubDocuments.Items[srvhftNormalHeader].LoadRVF(myPath + HeaderFN,
c, nil, nil);
if FileExists(myPath + FooterFN) then
sRveExport.SubDocuments.Items[srvhftFirstPageFooter]
.LoadRVF(myPath + FooterFN, c, nil, nil);
sRveExport.SubDocuments.Items[srvhftNormalFooter].LoadRVF(myPath + FooterFN,
c, nil, nil);
end
sRveExport.PageProperty.PageNoVisible := True;
sRveExport.Format;
Strange exception of TSRichViewEdit.SubDocuments
Re: Strange exception of TSRichViewEdit.SubDocuments
Can you create a simple project reproducing this problem?
Sorry,I forgot the NewItemAction event.
Then,how can I determine if the item is in the subdocuments,or it is in the TSRichviewEdit.RichviewEdit's content?
It's not very trivial.
OnItemAction has Sender and RVData parameters.
1) Sender may be SRV.RichViewEdit, SRV.RVHeader, SRV.RVFooter, SRV.RVNote, or a temporal editor used to draw inactive notes and text boxes.
But for SubDocuments, Sender = SRV.RichViewEdit, like for items in the main documents.
2) RVData is a document that contains this item.
It may be:
a) either RVData of the editors listed above (like SRV.RichViewEdit.RVData)
b) or one of SubDocuments[]
c) or a it may be a table cell or a note/textbox document; in this case, you can check RVData.GetAbsoluteParentData (or RVData.GetAbsoluteParentData.GetAbsoluteParentData and so on), until it will be one of (a) or (b).
It may be:
Copy it ! thanks a lot:)
