A TSRichViewEdit(in a frame),I set its externalRVStyle property, and use the codes to insert a hyperlink to jump to a url.
table.Cells[4, 1].AddNL('http://www.wolf1860.com',4,-1);
when click the hyperlink,it just open my application's root directory automatically,but not run the TSRichviewEdit.onjump event.
How should I do?
thanks!
TSRichViewEdit Insert a hyperlink to a cell
Re: TSRichViewEdit Insert a hyperlink to a cell
By default, clicking on a hyperlink does nothing, it should not open anything. So I think some code in your application reacts on clicking.
Please send me a sample project reproducing the problem.
Sorry,I forgot that there was a default method to handle the click event,so everything is ok:) thanks!
