ScaleRichview Document with Headers and Footers to PDF
rron
Post by rron »
I am trying to export a document to PDF using SynPDF. I am using the RV2PDF demo with RichView 18 and ScaleRichView 9 as an example. The issue is that the header and footer height is not correct in the PDF so I get more pages than my original document.
I have included a document with this issue.
DocumentWithHeaderFooter.rvf
(98.54 KiB) Downloaded 11218 times
Re: ScaleRichview Document with Headers and Footers to PDF
What code exactly do you use to create PDF?
You should not use code that includes TRVPrint or TRVReportHelper components for ScaleRichView.
The code must use TSRichViewEdit.DrawPage to draw pages in PDF.
rron
Post by rron »
I was indeed using TRVPrint and TRVReportHelper. Looking into into using Drawpage and some examples, I came up with this using llPDFLib :
function TRichViewMerge.ExportPdfToFile(PDFFileName: String): Boolean;
Var PDFDocument: TPDFDocument;
    PageSize: TSize;
    i: Integer;
Const PixelPerInch = 96;
    PDFDocument := TPDFDocument.Create(Nil);
    PDFDocument.FileName := PDFFileName;
    Try
        PageSize.cx := FScaleRichViewEdit.RichViewEdit.Style.RVUnitsToStandardPixels(FScaleRichViewEdit.RichViewEdit.DocParameters.PageWidth, FScaleRichViewEdit.RichViewEdit.DocParameters.Units);
        PageSize.cy := FScaleRichViewEdit.RichViewEdit.Style.RVUnitsToStandardPixels(FScaleRichViewEdit.RichViewEdit.DocParameters.PageHeight, FScaleRichViewEdit.RichViewEdit.DocParameters.Units);
        PDFDocument.Resolution := PixelPerInch;
        PDFDocument.BeginDoc;
        {PDF page size is measured in pixels, with DPI = PDFPixelsPerInch}
        PDFDocument.Page[0].Width := MulDiv(PageSize.cx, PixelPerInch, PixelPerInch);
        PDFDocument.Page[0].Height := MulDiv(PageSize.cy, PixelPerInch, PixelPerInch);
        For i := 0 To FScaleRichViewEdit.PageCount - 1 Do
        Begin
            if i > 0 then
                PDFDocument.NewPage;
                PDFDocument.Page[i].Width := PDFDocument.Page[0].Width;
                PDFDocument.Page[i].Height := PDFDocument.Page[0].Height;
            PDFDocument.Canvas.Font.PixelsPerInch := PixelPerInch;
            FScaleRichViewEdit.DrawPage(i + 1, FScaleRichViewEdit.PageWidth100Pix, FScaleRichViewEdit.PageHeight100Pix, 0, 0, PDFDocument.Canvas, False, False, False, False, False);
        End;
        PDFDocument.EndDoc;
    Finally
        PDFDocument.Free;
    End;
