When a rtf file contains \box tag for paragraph border then the paragraph is not shown in RichViewActionsTest demo application.
In Microsoft Word for example, it shows correctly.
Please advise.
Issue with box paragraph
- BoxParagraph.rtf
- (409 Bytes) Downloaded 1369 times
- BoxParagraphIssue.png (105.41 KiB) Viewed 20755 times
Re: Issue with box paragraph
The problem is not in \box, it is supported.
There was a bug in processing \brsp
It is already fixed in TRichView 18.1, but the compiled demos on the site were not updated.
(TRichView loads this border as a single-line border, because dotted paragraphs borders are not supported yet)
Hello,When a rtf file contains \box tag for paragraph border then the paragraph is not shown in RichViewActionsTest demo application.
Sorry for the delay, I'll check it after a release of Delphi 11-compatible version
