Debian x64 Lazarus and RVMedia 7.x not working with camera
I have setup a new Debian Buster (10.x = x64), installed Lazarus fixes 2.0 with FPC fixes 3.2. FFMpeg, v4l2 and gestreamer1.x is installed (gstreamer0.1 is not more available in Debian and Ubuntu).
Then i copied the files from a windows installation to the PC. I have tried the Lazarus Demo SwitchCamLaz, compiled and start but the programms freeze and nothing is shown.
The same Demo is running in windows out of the box, with the same camera.
Camera: Testing with a Logitech WebCam C930e
The camera is found under Debian as /dev/video2 and working with other software.
What is the best practice to bring the software working on linux.
Re: Debian x64 Lazarus and RVMedia 7.x not working with camera
I was diving into the code and found out, in TRVWebCam.PlayVideoStream the part where the camera is openend is never reached because State of the thread is set to run in the execute method, so the camera is not able to start.
i use this for testing (and it is selecting video0)
BTW:My cameras are on /dev/video0 (internal webcam) and /dev/video2 (external Logitech)
zus : string;
zus := '';
RVCamera1.DeviceType:= rvdtWebCamera;
RVCamera1.VideoDeviceIndex:=0;
if RVCamera1.IsSupportedGStreamer then zus := zus + ' GStreamer';
if RVCamera1.IsSupportedFFMPEG then zus := zus + ' FFMpeg';
Label1.Caption := RVCamera1.VideoDeviceList[0] + zus;
RVCamera1.PlayVideoStream;
Thank you for the information. There were last-time changed in our thread code for Linux, probably they affect web cameras. We are studying the problem.
Is it possible to get the older version (before the - i think - untested last-time change), because i need a working solution for a project with a v4l usb camera.
We fixed this problem in our working version.
Should I send fixed pas-files to you by email?
You're welcome. I'll test it as soon as possible.
THX
THX, i have tested, it works (basically).
*) The picture is flipped by 180 deg.
Mabe a wrong calculation in procedure TRVWebCam.GetFrame();
works for me.
*) There is a something going wrong in procedure TRVWebCam.SetVideoDeviceIndex(Value: integer);
Because only the first device is adressable. I think it should be
the 'Value' was ignored.
Regards
cur_p := Img.bitmap.ScanLine({Img.bitmap.height -} Y {- 1});
FVideoDeviceIndex := Min(Value, VideoDeviceCount - 1);
SetVideoDevice(FVideoDeviceIndex);
Regards
You fixes are correct, thank you!
