Installing for ONLY ONE version of Delphi?
alogrep
Post by alogrep »
Hi.
Is this possible? I have Delphi 10.2 installed, along with D5. Is it possible to install richview ONLY for 10.2 but not touch the D5 installation at all? If so, how?
Thank you
Re: Installing for ONLY ONE version of Delphi?
When running Setup, just uncheck Delphi 5. Delphi 5 will not be affected.
However:
- when uninstalling, it uninstalls TRichView from all Delphi versions.
- if you run "Install TRichView in Delphi IDE" shortcut in the Start menu and uncheck "Delphi 5", TRichView will be uninstalled from Delphi 5.
alogrep
Post by alogrep »
Hi
Sorry, there is no list of installations to uncheck (D5). I just ran the installation again (and cancelled immediately)
And it does not show anything about "uninstall"
Also I noticed that while running install.exe, in the same folder now there is another file "TRichView18Setup18.0.1.exe". Should perhaps run that executable instead? Or is that just a temporary file used by install.exe?
alogrep
Post by alogrep »
OK I solved it. I unselected "install IDE", then i went and executed "IDEInstall.exe" and there appeared the list of installed delphi versions.
Thanks.
