find first character
adamrich
Post by adamrich »
Is there a way to find first character in TRichViewEdit?
I'm trying to find if the whole document is started with character @
I can't get the text of TRichViewEdit to see if copy(RichViewEdit1.Text, 1,1)='@'
Thank you
Re: find first character
You can use the function GetAllText from RVGetTextW.
But it is not efficient, you just need the first character, not the whole string that can be several megabytes.
I can write a function, but some details must be clarified:
1) What if the document is started from non-text object (such as picture or horizontal line)?
2) What if the document is started from several empty lines? Space characters? Tabs?
3) What if the document is started from a table, and '@' starts the first cell?
adamrich
Post by adamrich »
Thanks for your time,
All I need to know if the document's first character @ or whatever I look for ,
if picture or anything else other than @ or table etc, that means the first character not @ (excluding the space and empty lines)
example
@ abc, <table> hello world (first character is @ on the first paragraph )
@ (excluding the space, the first character is @)
even with more than one line, here the first line or paragraph empty or filled with space
abcd @ (@ not first character)
<table> @ </Table> (@ not first character)
<Picture> @ (@ not first character)
Hope I could explained clearly :)
Thank you
This function returns the first non-space character (or #0, if the document is empty or started from non-text).
Empty lines, spaces and tab characters are ignored.
uses
  RVUni;
function GetNonSpaceFirstChar(rv: TCustomRichView): TRVUnicodeChar;
  i: Integer;
  s: TRVUnicodeString;
  Result := #0;
  for i := 0 to rv.ItemCount - 1 do
    if (rv.GetItemStyle(i) < 0) and (rv.GetItemStyle(i) <> rvsTab) then
      break
    else if rv.GetItemStyle(i) >= 0 then
      s := Trim(rv.GetItemTextW(i));
      if s <> '' then
        Result := s[1];
        break;
adamrich
Post by adamrich »
Thank you,
As always I appreciate your superb support, you never let your user down, best support ever.
Thanks again
