How get I full line text?
jasper13
Post by jasper13 »
Hi all,
I try to get a line text in TRichviewEdit, there's a small problem.
a line is, Example...
This is a test line...
S := rve.GetItemText(0) -> result S) This is a test line...
And I Change TextStyle to BOLD(or Underline, etc...) at a word in a line, Example...
and 'is a test line...' is Changed ItemNo = 1.
Thanks in advance!
Re: How get I full line text?
You can use the functions from RVGetTextW.pas:
- GetCurrentLineText - returns text from the current line (line bounds depend on word wrapping)
- GetCurrentParaText - returns text from the current paragraph (between breaks made by "Enter")
- GetCurrentParaSectionText - returns text from the current paragraph section (between breaks made by "Enter" or "Shift+Enter")
