Insert text at the beginning of a TRichView
Please tell me how to insert text at the beginning of a TRichView
Re: Insert text at the beginning of a TRichView
While TRichViewEdit has methods for insertion at the caret position, TRichView has only methods for adding to the end. The only exception is InsertRVFFromStream.
However, you can use the function from RVInsertItems.pas:
To insert at the beginning, the parameter ItemNo must be 0, like:
Please be careful when using this method, it may create an incorrect document when used incorrectly, see https://www.trichview.com/help/valid_documents.html
PS: this unit also has a method for inserting a picture:
procedure RVInsertString(RVData: TCustomRVData; ItemNo: Integer;
const s: String; StyleNo, ParaNo: Integer; const Tag: TRVTag = RVEMPTYTAG);
RVInsertString(RichView1.RVData, 0, 'Hello world!', 0, 0);
RichView1.Format;
procedure RVInsertGraphic(RVData: TCustomRVData; ItemNo: Integer;
Graphic: TGraphic; Hyperlink: Boolean; ParaNo: Integer;
VAlign: TRVVAlign = rvvaBaseline; const Tag: TRVTag = RVEMPTYTAG);
