[RichViewActions][Example] How to choose default UI language
User interface of RichViewActions is available in many languages.
The code below explains how to choose the default UI language depending on the Windows settings.
function GetSystemLanguage(var Language, Region: String): Boolean;
  Buf:    String;
  Len:    Integer;
  // Locale name format: Language[-[Script-]Region]
  Result := False;
  SetLength(Buf, LOCALE_NAME_MAX_LENGTH);
  Len := GetUserDefaultLocaleName(PChar(Buf), LOCALE_NAME_MAX_LENGTH);
  if Len = 0 then
  SetLength(Buf, Len-1);
  Len := Pos('-', Buf);
  if Len > 0 then
    Language := Copy(Buf, 1, Len-1);
    Region   := Copy(Buf, Len+1, MaxInt);
  end
    Language := Buf;
    Region   := '';
  if Region <> '' then
    Len := Pos('-', Region);
    if Len > 0 then
      Region := Copy(Region, 1, Len-1);
  Result := True;
function GetDefaultRVALanguage: TRVALanguageName;
  Lan, Reg: String;
  Result := 'English (US)';
  if not GetSystemLanguage(Lan, Reg) then
  if Lan = 'be' then Result := 'Byelorussian'
  else if Lan = 'bg' then Result := 'Bulgarian'
  else if Lan = 'ca' then Result := 'Catalan'
  else if Lan = 'cs' then Result := 'Czech'
  else if Lan = 'da' then Result := 'Danish'
  else if Lan = 'de' then Result := 'German'
  else if Lan = 'es' then Result := 'Spanish'
  else if Lan = 'fa' then Result := 'Farsi'
  else if Lan = 'fi' then Result := 'Finnish'
  else if Lan = 'fr' then Result := 'French'
  else if Lan = 'hi' then Result := 'Hindi'    // only for D2009+ or TNT
  else if Lan = 'hy' then Result := 'Armenian' // only for D2009+ or TNT
  else if Lan = 'hu' then Result := 'Hungarian'
  else if Lan = 'it' then Result := 'Italian'
  else if Lan = 'ja' then Result := 'Japanese'
  else if Lan = 'ko' then Result := 'Korean'
  else if Lan = 'lt' then Result := 'Lithuanian'
  else if Lan = 'ms' then Result := 'Malay'
  else if Lan = 'nb' then Result := 'Norwegian'
  else if Lan = 'nl' then Result := 'Dutch (NL)'
  else if Lan = 'pl' then Result := 'Polish'
  else if Lan = 'pt' then
    if Reg = 'PT' then
      Result := 'Portuguese (Portuguese)'
      Result := 'Portuguese (Brazilian)'
  end
  else if Lan = 'ro' then Result := 'Romanian'
  else if Lan = 'ru' then Result := 'Russian'
  else if Lan = 'sk' then Result := 'Slovak'
  else if Lan = 'sw' then Result := 'Swedish'
  else if Lan = 'th' then Result := 'Thai'
  else if Lan = 'tr' then Result := 'Turkish'
  else if Lan = 'uk' then Result := 'Ukrainian'
  else if Lan = 'zh' then
    if Reg = 'CN' then
      Result := 'Chinese (Simplified)'
      Result := 'Chinese (Big5)'
How to use:
Let we have a form that uses the actions and contains RVAControlPanel1: TRVAControlPanel
(normally, you should have a single TRVAControlPanel in your application, it becomes default).
When this form is created, assign:
  RVAControlPanel1.Language := GetDefaultRVALanguage;
After that, call the code that applies the current language (containing the procedures like RVA_LocalizeForm, RVALocalizeRuler, etc.). In our ActionTest projects, this code is inside the Localize method of the main form.
