Some questions about RichView
voodoo
Post by voodoo »
I load a text file into a RichEditView. This text file can contain control characters (Form Feed, Escape sequences, etc) because the file is the print file coming from an external procedure.
I want:
a - Split the file in pages, each page with max. N lines.
b - Convert each page into a bitmap/metafile, but without blank margins around, only the full text.
It's possible?
Yernar Shambayev
Re: Some questions about RichView
Post by Yernar Shambayev »
voodoo wrote:I load a text file into a RichEditView. This text file can contain control characters (Form Feed, Escape sequences, etc) because the file is the print file coming from an external procedure.
I want:
It's possible?
I believe if the file contains the special control characters, it's not a text file.
Text loading methods recognize Form Feeds, but do not recognize Escape sequences.
There are no methods/properties allowing to set max N of lines on page. And WYSIWYG is not implemented, so lines may break in different places on paper and in editor.
You can convert each page to image using TRVReportHelper component.
Margins are defined in RVReportHelper.RichView.LeftMargin, RVReportHelper.RichView.TopMargin, ... (can be zeros)
