Hello Sergey
I would like to format a text from clipboard from another document according to the formatting of the field being pasted, how do we proceed?
We are pasting into a TRichViewEdit component.
thanks
Format a text from Clipboard
Re: Format a text from Clipboard
Sorry, I do not understand the question. Can you give an example?
I want to clear the formatting when pasting a copied text.
Sorry for my English.
Call PasteTextW instead of PasteDef.
If you use RichViewActions, you can use TrvActionPasteAsText. Its default shortcut is Shift+Ctrl+V (Edit | Paste as Text command).
It worked!
Thanks Sergey
Thanks Sergey
