Hello, Sergey.
How to disable drag-and-drop an image from the editor?
Disable drag-and-drop an image
Re: Disable drag-and-drop an image
You can only disable drag&drop from TRichView completely.
Include rvoDisallowDrag in the Options property.
Is included, and allows drag and drop
If included, drag&drop FROM this editor is not possible. But it does not prevent dragging INTO this editor.
To disable accepting all/some format from drag&drop, exclude values from AcceptDragFormats property.
It worked.
Thanks Sergey!
Thanks Sergey!
