I'm using Rad2010+RVCamera to access the built-in webcam on a surface pro4 device.
I'm wondering if it's possible to preview & take photo by RVCamera component.
It seems that only video stream is supported and the available max resolotion is 1920*1080.
Looking forward to your response, thx a lot!
How to control webcam to preview and take photo by RVCamera?
Re: How to control webcam to preview and take photo by RVCamera?
I'm not familiar with RVMedia.
But I imagine this is what you want:
https://www.trichview.com/help-media/in ... apshot.htm
Yes, I've tried this one, it can only get a picture with the same resolution as the video(1920*1080 pixels).
But I'd like to take photos with much higher resolution(3264*2448 pixels) which the sensor is acutally capable of.
In other words, I want to make the camera work at "photo mode" instead of "video mode".
You got any idea of this? Thanks a lot!
No, it's not possible. RVMedia makes snapshots at the same resolution as the current camera video mode.
You can switch camera to high-res mode, make a snapshot, than switch it back.
The demo for switching video modes is in <RVMedia dir>\Demos\Delphi\Cameras\WebCam\
Hi Sergey, thx for ur reply.
I tried to run this sample on Surface Pro4 but 1920*1080(1920*1080 16bits YUY2) is the highest one in all listed resolutions.
It seems that only those resolutions that supported under "video mode" are enumerated. Why is that?
Some resolution may use encoding unsupported by RVMedia, or not accessible using DirectX method that RVMedia uses.
RVMedia lists all supported video modes.
OK, I see.
And do you have any plan/intention to use media foundation in the future?
Thx!
Thx!
Probably, there are no definite plans about it yet.
There are works with higher priority (FireMonkey, different platforms, ONVIF support)
