Cursor not showing when TSRichViewEdit is in a VCL Frame
rron
Post by rron »
If I place a TSRichViewEdit in a frame, the cursor is not shown. When I place the same TSRichViewEdit directly in the form that contains the frame, the cursor is visible (and blinking). Using Delphi 10.3 Rio and ScaleRichView-Pre9.
Re: Cursor not showing when TSRichViewEdit is in a VCL Frame
I confirm the problem.
Quick fix: open <TRichView Dir>\ScaleRichView\Source\SclRView.pas, add to the end of the procedure TSRichViewEdit.CreateWnd:
  if srvs_TimerCaret in FState then
    UpdateCaretTimer;
Tavo
Post by Tavo »
Hi!
I recently updated my version of ScaleRichView. I find this same problem: Cursor not showing when TSRichViewEdit is in a VCL Frame.
The same form (with a frame with a ScaleRichView) was working well until the update. The only problem that I have detected so far is that the cursor does not to blink.
Within TSRichViewEdit.WndProc(), execution enters into the second IF only once, at first. Is that data useful?
In SclRView.pas
procedure TSRichViewEdit.WndProc(var Message: TMessage);
  inherited;
  if IsNotRunTimeMode then
  if not(srvs_TimerCaret in FState) and HandleAllocated then
    Include(FState, srvs_TimerCaret);
    FPageProperty.PageWidth := FPageProperty.PageWidth;
    FPageProperty.PageHeight := FPageProperty.PageHeight;
    UpdateView;
    UpdateCaretTimer;
    OldPageCount := 0;
    CalculatePageCount;
Thanks for readme
Did you apply the fix I posted in this topic?
Tavo
Post by Tavo »
Hello Sergey, thanks for answering.
I had not done it because-this post being so old-I thought it was already incorporated into the library.
I just did it and it works perfect! :-)
Thank you!
Pieter E.
Post by Pieter E. »
Hi, last week I upgraded TSRichViewEdit to the latest version. I found out that this issue is not fixed in the latest release. Is there a specific reason why this fix is not included?
Because there were no updates yet. The next update is almost ready, it will be released in this week.
Pieter E.
Post by Pieter E. »
Thank you for your answer. Looking forward to see the new update. :D
