Delphi 10.3 Rio was officially released today.
Will the current version of TRichview work with 10.3 or should I hold off installing 10.3?
Delphi 10.3 Rio Compatibility?
Re: Delphi 10.3 Rio Compatibility?
No, the current version is not compatible with 10.3. We will upload a compatible version ASAP, but at least a couple of days is needed.
Well, it is taking more time than I expected. It's not a problem to compile install the last released version in Rio, only a few simple changes are needed.
However, I want to support new features - TVirtualImageList and "Per Monitor v2", and it's a lot of work...
Let me know if you need Delphi 10.3 compatible version urgently, I'll send it to you.
I just uploaded TRichView 17.6. It supported RAD Studio 10.3 Rio.
However, it does not include everything I wanted to implement to support Rio, so the next update will be released in the next week.
