Hello!
How to calculate amount of memory that using by implantation of TRichView object?
Get TRichView object data size
Re: Get TRichView object data size
Sorry, for TRichViewEdit class
It's not a trivial task, because TRichView contains many objects.
You can use FastMM to check the allocated memory before and after loading a document, see the accepted answer here: https://stackoverflow.com/questions/156 ... t-or-class
