Duplex printing error
alisichkin
Post by alisichkin »
Hello!
Thanks for helping to solve the print header/footer problem.
In our extended version of RichView (15.1.2), an error occurred in two-sided printing (duplex) for multiple copies.
The error appears in the module SRVPrint.pas
The TSRVPrint.PrintPages procedure does not use the TDeviceMode.dmDuplex value.
Therefore, when print 2 pages report, with two-sided pages, with 2 copies, with turned off collate parameter, the indexPage variable is not correctly calculated.
indexPage changes 1,1; 2,2
But should be 1,2; 1,2.
procedure TSRVPrint.PrintPages(firstPgNo, lastPgNo: Integer; Title: String;
  Copies: Integer; Collate: Boolean);
  Step, indexPage, indexCopys, indexCopys2, PrintCopies, OldPrintCopies,
    CountPageAtPaper, j, EP: Integer;
  OldOrientation:            TPrinterOrientation;
  StartPrint:                Boolean;
  if Printer.Printers.Count = 0 then
  SRVPrtInfo.UpdateCurPrinterData;
  Printer.Title := Title;
  firstPgNo := Max(Min(firstPgNo, FSRichViewEdit.PageCount), 1);
  lastPgNo := Max(Min(lastPgNo, FSRichViewEdit.PageCount), 1);
  OldPrintCopies := Printer.Copies;
  if Collate then
    Printer.Copies := 1;
    PrintCopies := Copies;
  end
    PrintCopies := 1;
  if PrintMode = srvpTiles then
    CountPageAtPaper := Max((Floor(PageWidthPix) div Floor(TotalFrameWPix)), 1)
      * Max((Floor(PageHeightPix) div Floor(TotalFrameHPix)), 1)
    CountPageAtPaper := 1;
  lastPgNo := Min(SRichViewEdit.LastPageNo, lastPgNo);
  BeginUpdate;
  StartPrint := True;
  OldOrientation := Orientation;
  Printer.Orientation := Orientation;
  Printer.BeginDoc;
  if Assigned(FOnSendingToPrinter) then
    FOnSendingToPrinter(SRichViewEdit, 0, 0, rvpsStarting);
  for indexCopys := 1 to PrintCopies do
    if (FPrintMode = srvpGrid) then
      Step := PageColCount * PageColCount
      Step := CountPageAtPaper;
    indexPage := Max(SRichViewEdit.FirstPageNo, firstPgNo);
    while (indexPage <= lastPgNo) do
      if not Collate then
        for indexCopys2 := 1 to Copies do
          if not StartPrint then
            Printer.NewPage;
          StartPrint := False;
          EP := Min(indexPage + CountPageAtPaper - 1, lastPgNo) - 1;
          EP := (EP div CountPageAtPaper) * CountPageAtPaper +
            (EP mod CountPageAtPaper) + 1;
          for j := indexPage to EP do
            PrintFramesEx(j);
        end
          Printer.NewPage;
          PrintFramesEx(j);
      indexPage := (((indexPage - 1 + Step) div CountPageAtPaper) *
  Printer.EndDoc;
  Printer.Orientation := OldOrientation;
    FOnSendingToPrinter(SRichViewEdit, 0, 0, rvpsFinished);
  EndUpdate;
  Printer.Copies := OldPrintCopies;
Could you help me to fix this procedure?
Alexander.
Re: Duplex printing error
In newer version of the components, if collate is turned off, and the printer supports copies, TSRVPrint allows printer to handle copies itself.
MitchellBon
Post by MitchellBon »
Why does the collate have to be turned off for the TSRVPrint to allow printer to handle copies btw? What am I missing?
There are printers that do not support copies. For these printers, SRVPrint handles copies and collating itself.
There are printers that support copies but do not support collating. For these printers, SRVPrint relies on the printer when printing without collating, and handles copies and collating itself otherwise.
There are printers that support collating. SRVPrint does not have a special support for them and handles them like previous printer.
Do you have a printer that supports collating itself?
