Remove "nearest" checkpoint
Rael Bauer
Post by Rael Bauer »
I want to remove the "nearest" checkpoint - meaning the nearest checkpoint going "backwards", but not beyond the current paragraph.
function TForm1.CheckPointNumber(rve: TCustomRichViewEdit): Integer;
  i: Integer;
  Result := -1;
  rve := rve.TopLevelEditor;
  i := rve.CurItemNo;
  while not rve.IsParaStart(i) do
    if rve.RVData.GetItemCheckpoint(i) <> nil then
      Result := i;
    dec(i);
    Result := i;
procedure TForm1.miRemoveCheckpointClick(Sender: TObject);
  if Self.CheckPointNumber(rve) > -1 then
    rve.RemoveCheckpointEd(CheckPointNumber(rve));
    //rve.Invalidate;
This works for me in a normal document, but does not handle Table cells. How can I also handle table cells with the same logic?
Re: Remove "nearest" checkpoint
Simply apply this code to TopLevelEditor:
  Editor: TCustomRichViewEdit;
  CPNumber: Integer;
  Editor := rve.TopLevelEditor;
  CPNumber := CheckPointNumber(Editor);
  if CPNumber >= 0 then
    Editor.RemoveCheckpointEd(CPNumber);
