Text formatting color problem
wsy211
Post by wsy211 »
The novice consult.
How to achieve when encountering the string text color of the paragraph with the first letter "A:" is A color; When you encounter the string text color of the paragraph with the first letter of "B:", it changes to another color.
See rendering
How is the code implemented, thanks for your help
Re: Text formatting color problem
uses RVTypes;
type
  TTextColorPair = record
    Text: TRVUnicodeString;
    Color: TColor;
  TTextColorPairs = array of TTextColorPair;
// Returns color for Text from the rules listed in TextColorPairs
function GetColorForText(const Text: TRVUnicodeString;
  const TextColorPairs: TTextColorPairs): TColor;
  i: Integer;
  Result := clNone;
  for i := Low(TextColorPairs) to High(TextColorPairs) do
    if Copy(Text, 1, Length(TextColorPairs[i].Text)) = TextColorPairs[i].Text then
      Result := TextColorPairs[i].Color;
// Returns index of in rvs.TextStyles of the style having all properties of
// rvs.TextStyles[StyleNo], but the specified color.
// If it does not exist, it is created
function GetStyleNoWithColor(rvs: TRVStyle; StyleNo: Integer; Color: TColor): Integer;
  TextStyle: TFontInfo;
  if rvs.TextStyles[StyleNo].Color = Color then
    Result := StyleNo;
  TextStyle.Assign(rvs.TextStyles[StyleNo]);
  TextStyle.Color := Color;
  Result := rvs.FindTextStyle(TextStyle);
  TextStyle.Free;
// Changes colors of text in rv basing on rules specified TextColorPairs
procedure ColorLines(rv: TCustomRichView; const TextColorPairs: TTextColorPairs);
  i: Integer;
  Color: TColor;
  Color := clNone;
  for i := 0 to rv.ItemCount - 1 do
    if rv.IsParaStart(i) then
      if rv.GetItemStyle(i) >= 0 then
        Color := GetColorForText(rv.GetItemTextW(i), TextColorPairs)
        Color := clNone;
    if (Color <> clNone) and (rv.GetItemStyle(i) >= 0) then
      rv.GetItem(i).StyleNo := GetStyleNoWithColor(rv.Style, rv.GetItemStyle(i), Color);
How to use:
  ColorRules: TTextColorPairs;
  SetLength(ColorRules, 2);
  ColorRules[0].Text := 'A';
  ColorRules[0].Color := clRed;
  ColorRules[1].Text := 'B';
  ColorRules[1].Color := clBlue;
  ColorLines(RichViewEdit1, ColorRules);
  RichViewEdit1.Invalidate;
This code changes color of all text in paragraphs. Probably, it makes sense to change only text having the default color (clWindowText).
In this case, ColorLines must be:
  i: Integer;
  Color: TColor;
  Color := clNone;
        Color := clNone;
    if (Color <> clNone) and (rv.GetItemStyle(i) >= 0) and
      (rv.Style.TextStyles[rv.GetItemStyle(i)].Color = clWindowText) then
wsy211
Post by wsy211 »
Sergey Tkachenko Thank you very much
