RichViewActions 7.2 - Lazarus
TRichView and RichViewActions have been updated.
Trial versions can be downloaded here: https://www.trichview.com/download/
The main feature of this update is compatibility of RichViewActions with Lazarus.
All actions and dialogs are ported. High-dpi and right-to-left compatibility of dialogs and additional components are tested and work.
The only LCL limitation: TRVAFontComboBox cannot display font previews in csSimple mode.
Additional components allowing to work ASpell, HunSpell and Indy with RichViewActions are ported as well.
ASpell and HunSpell demo projects with RichViewActions are ported.
A trial version for Lazarus is available on the download page (Installation instructions). RichViewActions are available in a source code even in the trial setups.
Previous version
https://www.trichview.com/forums/viewto ... f=6&t=9244
Re: RichViewActions 7.2 - Lazarus
Some tweaks were made to support high-dpi display modes in RichViewActions dialogs better.
For example, toolbar icons in the print preview dialogs were changed.
The new print preview icons are available in different sizes, the proper size is chosen depending on the screen dpi.
(previously, this dialog has 16-color toolbar icons and they were scaled according to the screen dpi)
