GetItemTextR
jota
GetItemTextR
Post by jota »
Hi
The following function produces an error when compiling with trichview 17, because the "GetItemTextR" method does not exist
Who can give me an alternative that works. Thanks in advance
function GetItemText2Mod(RVData: TCustomRVData; ItemNo: Integer): TRVAnsiString;
  if RVData.GetItemStyle(ItemNo)>=0 then
    Result := RVData.GetItemTextA(ItemNo)
  else if RVData.GetItem(ItemNo).GetBoolValue(rvbpAlwaysInText) then
    Result := RVData.GetItem(ItemNo).AsText(0, RVData, RVData.GetItemTextR(ItemNo), '', True, False, 0)
    Result := '';
Re: GetItemTextR
It was removed because it makes no sense now, because all text is stored as Unicode.
Also, the parameters of item.AsText were changed.
What's the purpose of this function? How do you use its result?
jota
Re: GetItemTextR
Post by jota »
I compose a text string, concatenating each line of a 'tdbrichview', stored in rvf format, in a blob field in the database.
Some lines contain information such as the following.
'Name'#$D#$A'Discount'#$D#$A'Others'#$D#$A'10.03.2011 – 11.03.2011'#$D#$A
#9
With this code in function 'GetItemText2Mod' I try to include in the string, the text that contains the previous example lines.
Is this wrong?, there is an alternative?
Thank you for your attention
Re: GetItemTextR
Do you want to store a text representation of TRichView in a separate field?
In this case you can use functions from RVGetText.pas (or, if you need Unicode text, from RVGetTextW.pas).
If you need this text to implement a full text search, it's better to use RVGetTextRange from RVLinear.pas instead
jota
Re: GetItemTextR
Post by jota »
Hi, thank you so much for everything.
