TRichView 17.5 - Lazarus
TRichView 17.5 has been uploaded.
Trial versions can be downloaded here: https://www.trichview.com/download/
The main feature of this update is compatibility with Lazarus.
The following sets of components are ported to Lazarus:
- TRichView
- RichViewXML
- parsers for HunSpell and ASpell
- RvHtmlImporter
All these components are available for Windows 32-bit and 64-bit platforms (but TRVASpell and TRVOfficeConverter use 32-bit DLLs, so they do nothing when compiled in 64-bit).
A trial version for Lazarus is available on the download page (Installation instructions)
Additional information about Lazarus support: https://www.trichview.com/help/lazarus.html
To-do: we plan to port RichViewActions, ScaleRichView and Report Workshop to Lazarus.
Previous version
https://www.trichview.com/forums/viewto ... f=6&t=9131
Re: TRichView 17.5 - Lazarus
License
Our components are not free and not open source. We provide source code to our customers after purchase.
The terms of license are the same for using in Delphi and in Lazarus: https://www.trichview.com/order/license-trichview.html
You do not need to order a license for using our components in Delphi and in Lazarus separately: after the purchase, you can use our components in Delphi, C++Builder and Lazarus, without additional payments.
